valve springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2010, 08:45 PM
valve springs
what method(s) are used to determine valve spring problems? tks in advance.
Old 04-02-2010, 03:15 PM
texas97z's Avatar
Last journal entry: A little progress and maybe new paint
Would need more info on what problem you are having. Also "valve springs" are an engine component, not suspension. So are you referring to springs for suspension or valvetrain?
Old 04-02-2010, 07:32 PM
valve springs
engine valve springs as in engine component NOT suspension NEW KID here!! have a popping sound emitting from flowmaster exhaust with "h" pipe. heard from unofficial sources that this may be a valve spring issue. removed valve covers, rotated engine via relay and saw nothing abnormal, all valves appeared to intake/exhaust the same distance, these are double springs. Engine sees 5800-6000 routinely 1/8th mile. So, the mystery is to narrow down to which cylinder is producing the "POP", steps to take and in what order to track down the culprit. Block is 440HP circa 1967, bored .40 over, w/edelbrock alum performer heads (83?cc), w/1.6 adjustable roller rockers (crane), crane push rods and a Schneider 284/530 solid lifter cam, hi rise single plane, proform 850 mech, msd electronics. tks in advance for ANY direction that can be provided. Jim (USN/RET)
Old 04-03-2010, 12:08 AM
This is a engine area question ... so as a Moderator, I am moving it there
What type of cam has the least chance of failing? 4speed57 Engine 24 01-29-2010 04:46 PM
Dual valve springs and seal clearance ? rockdawg Engine 5 01-10-2010 05:52 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
valve springs, valves, push rods, and rocker arms elcaminodragster Engine 7 01-28-2008 09:48 AM
Valve springs @seals JMEDLEY001 Engine 1 12-12-2006 10:25 PM
