i have a 80 chevy truck with a 305 in it. i am about to put a holley carb, edelbrock performer intake, headers and a summit racing brand cam in it with z28 valve springs on it i believe they have a .550 lift cam max. My question is a guy up at work told me that if i put on springs that i will have to put on performance rockers and pushrods to. or i will crack a rocker arm or shoot a pushrod though the valve covers. the two cams i would like to go with is
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,500-4,000 RPM
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 272
Advertised Duration: 262 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
Lobe Separation (degrees): 112
AND
Brand: Summit
Product Line: Summit Cam and Lifter Kits
Basic Operating RPM Range: 2,000-4,500 RPM
Intake Duration at 050 inch Lift: 214
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 214 int./224 exh.
Advertised Intake Duration: 272
Advertised Exhaust Duration: 282
Advertised Duration: 272 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.442
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465
Valve Lift with Factory Rocker Arm Ratio: 0.442 int./0.465 exh. lift
which one would you recommended so that i could just buy springs instead of rocker arms and pushrods. or is the guy pulling my leg.
thanks for the help
AND
Brand: Summit
thanks for the help
