Valve springs, heights and rates. ?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-04-2011, 07:11 AM
F-BIRD'88's Avatar
Yada Yada Yada
I would start by removing one spring and measure the real installed height of that spring. Then take the spring to a shop and heve them measure the real pressure at that height. And the open pressure at full lift. if it is in a acceptable range go with it.
To aid cam break in temp install stock SBC valve springs at 1.75" ++ (tall) installed height. (stock sbc retainers with no shims or oil cap.)
Reduced spring pressure.
Get them from a old junk stock SBC head. Reinstall the correct springs at the correct installed height once its all broke in.
For long cam/lifter life try to avoid more than 360# open or 140# seat pressure.
The installed height can be juggled with + or - .050" height locks and shims.
Anything around 100 to 125# seat and 290-350# open will work.
But its up to you the installer to check and verify correct spring specs.
deck heights in an SBC kc8oye Engine 33 12-30-2010 05:43 PM
Piston pin heights. Hippie Engine 6 12-15-2009 08:16 PM
Valve Springs camaro409 Engine 12 02-18-2004 01:32 PM
bbc intakes & heights reegeemon Engine 5 01-27-2004 07:40 AM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 05:23 PM
