Valve Springs Lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2008, 09:36 AM
juiced66malibu's Avatar
Valve Springs Lift
I will be ordering either beehive or double valve springs for a hydraulic roller cam that lifts 0.558/0.558.
The Comp double valve springs has it stated as: valve lift up to 0.560 and another one up to 0.600. Is the clearance for the 0.560 spring ok or should I go to the 0.600 spring instead?
Also, what is better to use between the beehive vs, double valve springs.
My Chevelle is a week-end cruiser with some highway miles. Will take it to the 1/4 track about 12x this year.
Old 03-08-2008, 10:49 AM
the specs of the spring has to match the requirements of the cam manufacturer
Old 03-08-2008, 11:54 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You might try reading this.
Rich
http://www.cranecams.com/?id=5&show=faq
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
Valve Springs 71 c-10 Engine 14 11-02-2007 09:55 PM
What is the actual valve lift? firewood Engine 3 07-21-2003 11:49 AM
Valve Springs GearHead69 Engine 5 07-19-2003 11:00 AM
