Hello, here is a link to the original post about me discovering valve seal bits and inner dampner pieces under my valve covers.
http://www.hotrodders.com/forum/some-debris-drain-plug-magnet-379282-3.html
The truck sat in a shop for over a week only for the guy to call me telling me he quoted me wrong by over double and it was going to be 500+ $ to replace valve seals.
I wen't ahead and drove my truck out of there.
Now i'm pretty lost as to what to do, I have myself convinced that this was not an issue caused by valve float or loft from over revving.
I believe these were incorrect springs for my heads and the inner dampners broke from hitting the valve guide boss then the broken pieces tore up my seals.
Specs 135 lbs. @ 1.750, 325 lbs @ 1.200
Springs are 1.250 diameter
I am trying to find the correct parts for my application, I have a voodoo hyd roller cam in my engine
Advertised Duration (Int/Exh): 270/278
Duration @ .050 (Int/Exh): 219/227
Gross Valve Lift (Int/Exh): .515/.530
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6000
Could someone please point me in the right direction for some springs, keepers and retainers that will work for me and my vortec heads?
I assume I could simply remove the inner dampner from my current springs, replace the seals and then maybe be back on the road but I don't want to cut any corners.
Here is the original sale ad for the vortecs, they were supposed to be ready for a 600+ lift cam.
Small Block Chevy Vortec
Racing Heads Custom
Head Castings # 906
Cut to 59CC Chambers
Never been used since built.
Heads have 1.94 Intake Valves
1.5 Exhaust Valves
All Stainless Steel 1 piece Swirled Polished Competition Series Valves.
Custom 3 Angle Valve Job
Cut for Positive type Valve Seals installed.
Screw In Studs & Guide Plates were installed.
New Valve Springs and Retainers, Keepers
Springs are good for 600 Lift Cam.
No port work has been done to heads.
Heads have been drilled to except early 12 bolt intake manifolds.
Professionally done.
LSA/ICL: 112/106
Racing Heads Custom
Head Castings # 906
1.5 Exhaust Valves
