Valve stem seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2006, 10:27 AM
Valve stem seals
Is there a kind of valve stem seal for small Chevys that looks similar to a normal o-ring, only square not round? What motors and years would it fit? I found 16 of these rings in my Felpro gasket kit but this is not how I expected a stem seal to look like.
Regards
Martin
Old 03-26-2006, 10:31 AM
MI2600's Avatar
Member# 3287
Those are the original style valve seals for the two-groove valves. There are used every day in about two bzillion GM engines.
Old 03-26-2006, 10:38 AM
Ok, so I can expect a 1980 305 to use these stem seals? I actually need to change them but haven't removed a spring yet to see what's there.
Regards
Martin
Old 03-26-2006, 04:31 PM
BOBCRMAN@aol.com's Avatar
The O-ring seals were used up till the early-mid ninetys. Even after the engines went to positive seals.
When you remove the valve locks and retainer you will see two grooves in the valve. The lower one usually has a hardened semi-brittle old seal in it.
When you re install the assembly. Just before installing the locks. Slip the seal over the valve and locate it to the lower groove.
« cylinder help | 350 »
305 engine valve stem seals pablo Engine 4 11-21-2007 10:30 AM
valve stem size? Turbo Terror Engine 1 02-06-2006 09:25 AM
Best SBC Valve guide seals? Sagacious Engine 9 05-03-2005 07:06 AM
351 Cleavland valve seals ImaPseudonym Engine 6 10-28-2002 03:43 PM
valve stem seals HQ Pete Engine 2 04-02-2002 12:04 AM
