valve stem size - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 06:50 PM
aceofspades49c's Avatar
Cobra killa
valve stem size
i have a set of chevy 350 heads that today i was going to put brand new intake and exhaust valves
that the stem measurement was 11/32, but when i went to slip the new valves in they didnt fit. then i looked at the heads more carefully and seen that they have a sleeve in the valve guide, i measured and its a bit less then 11/32, i looked in all my parts books and can t find any valves smaller than 11/32 ???? does any one know what happen to my heads or are there special valves for replaced valve guides in the cylinder head,or do i have to take them to the machine shop to get 11/32 valvew guides in it???? here are some pics. left is the new 11/32 exhaust valve, right is old exhaust valve with unknown stem size
other pic is intake port with sleeve like thing
ID:	10513   Click image for larger version
Old 03-04-2006, 07:10 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
were these some kind of special high-po heads or something? i'm just thinking that maybe somebody decided to put in some 5/16" guides and valves. i know there is mopar 5/16" valves.
JB
Old 03-04-2006, 07:33 PM
BOBCRMAN@aol.com's Avatar
Your heads were probably done by a commercial rebuilder.. The inserts are bronze liners that are normally inserted in a properly resized guide to bring the ID. back to standard dimensions. Looks like maybe the rebuilder was using "reground" valves with smaller OD. stems.. You will need to take the heads to a local shop that is using liners and have the guide broached or sized to your new valves.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 01:48 PM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
oil being sucked threw the pcv valve on my 350 sb.. Robbie Engine 23 05-08-2004 09:12 AM
Valve stem size 87442lover Engine 9 10-30-2003 12:06 PM
