valve tapping???? 69 chev malibu 307 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2003, 01:20 PM
New Member
recently when i went to start my car there was some knocking that went away pretty quick after i was cranking the starter, then i noticed it was randomly knocking while running... but goes away when i excelerate... (i thought it would get louder but it seems to go away) so i took off the valve covers and tried to tighten any that seemed loose and i also think i found out which one was knocking by disconecting the spark plug to it. Anyhow I've taken off the covers and tightened the valves quite a few times trying to take care of the tapp and although it';s better it's still randomly tapping.... Just wondering if anyone has any ideas and also wanted to ask.. should there be any play in how tight the top peice is? I hate to sound amature but the little scoup type thing.. should i be able to move it at all or should i tighten it down solid?? thanks
Old 11-27-2003, 03:23 PM
BOBCRMAN@aol.com's Avatar
It could be a rod bearing bad and the piston hitting on the head or a broken piston, both would cause noise. Have an experianced mechanic listen to it!
Old 11-27-2003, 04:15 PM
lluciano77's Avatar
Re: valve tapping???? 69 chev malibu 307
If you are talking about the rocker arm it depends on what type it is.
Old 11-29-2003, 01:07 AM
If you tighten it down solid you will damage your engine for sure.
« 308 | Inline six »
