Valve Train Help!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2007, 10:37 AM
Valve Train Help!!!
I need to change at least two valves on my 72 Comet. Its a 302 with 289 heads. Its has Chevy valves 202 & 160. Ive never changed valves before. Can someone please explain the steps to me please? Any tips would be greatly appreciated.
Old 06-24-2007, 01:04 PM
boatbob2
change valves
remove carb and linkage, mark position of dist rotor,remove dist.,remove intake manifold,remove accessories,ac pump,alternator (if there in the way.) remove exhaust manifolds, remove cylinder head bolts.using valve spring compressor,remove valve keepers and springs.remove valves.hand grind valve seats (if applicable) replace valves. reinstall with new head gaskets and intake manifold gaskets. torque to specs. replace acessories,carb and linkage. replace dist,with rotor pointing in marked direction. replace exhaust manifolds
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
Bad Air Valve black66 Electrical 8 04-12-2005 12:44 PM
Valve train buildup questions. Shades Engine 1 09-29-2004 03:33 PM
valve train tick KeithB123 Engine 7 12-04-2003 05:35 PM
Residual Pressure Valve?? Dave E Shank Suspension - Brakes - Steering 1 12-27-2002 07:12 PM
