Sure sounds like the springs......Were they checked?
Replace the springs and try it..........they probably need replacing anyways.
Ontario Rodders |
Nope, unfortunately the heads ended up being a rush job (long story here but me and this machinist parted ways over the head job). What do you think about the lifters? Could they also cause it or not likely?
The performer cam is only advertised good to 5500 anyway. Pulling it passed that won't gain you anything. I don't see the lifters being the problem. The cam/springs/heads are.
springs
If they are stock springs then there is a good chance there are junk.. I doubt it's the lifters..
Even if you swap the springs out don't expect much above 5000 rpm with that cam and a set of stck 305 heads...You may be able to spin it to 6000 with new springs but there is no reason to. Keith |
Yeah, I didnt expect to get a high revving motor out of this but I did kind of hope for up to 6K. The heads are 416s and have had the standard 1.84"/1.5" valves replaced with 1.94"/1.6" valves and had some deshrouding done. The HP was max at 5400 rpm and then the floating at 5500 so I was thinking that maybe if I could get it to turn a little more then I could squeek a few more ponies out of it. Wishful thinking? lol Well, I tried.
Your dyno guy should be able to tell from the EGT and A/F mixtures.
If it went stupid rich, the ignition probably broke down. The EGT will spike when the valves are floating. |
| 700R4 – Why are the TCI manual valve body instructions so lousy? | Bayley | Transmission - Rearend | 24 | 02-16-2009 12:49 PM |
| Bad Air Valve | black66 | Electrical | 8 | 04-12-2005 12:44 PM |
| Valve train buildup questions. | Shades | Engine | 1 | 09-29-2004 03:33 PM |
| valve train tick | KeithB123 | Engine | 7 | 12-04-2003 05:35 PM |
| Residual Pressure Valve?? | Dave E Shank | Suspension - Brakes - Steering | 1 | 12-27-2002 07:12 PM |
