valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2009, 02:26 PM
valves
can you put chevy 350 valves in a 305
Old 09-01-2009, 04:08 PM
Yes the seats can be reshot for 1.9 and 1.55 350 valves.
Bogie
Old 09-01-2009, 04:11 PM
so stock valves should work if they are both stock heads
Old 09-01-2009, 04:57 PM
BOBCRMAN@aol.com's Avatar
You better check what your local shop charges to do this. Done correctly won't be cheap!!
Old 09-01-2009, 05:12 PM
so it would be eaiser to just get a valve from another 305 head
Old 09-01-2009, 05:21 PM
ericnova72's Avatar
More for Less Racer
It isn't just a matter of 305 head or 350 head, they shared some stuff. There are two different intake valve head sizes used on a 305 - 1.72" and 1.84" . There are three different intake valve sizes used on 350 engines - 1.72", 1.94", and 2.02". As you can see, they only overlap on only one size.
The size that is in any particular head is dependant on what the original horsepower application was and not just the cubic inch size of the engine.
best way of adjusting valves SBC ??? Augusto Engine 33 03-22-2011 06:04 AM
Lapping New Valves - Help leejoy Engine 11 11-10-2007 09:56 AM
NASCAR, Unleaded Fuel and Titanium Valves QuenchPiston Engine 18 12-26-2006 09:18 PM
Adjusting Valves and Fuel Pump Install demitristewart Engine 5 08-09-2006 11:10 AM
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 01:19 AM
