Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - valves
Thread: valves
Old 12-15-2002, 03:21 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Post
There's no set height on the guide bosses so whats probably happening is you simply run out or adjustment on those respecting valves. Its possible to have the bosses machined to lower thier hieght. If you don't wanna pull the heads than you can get even longer pushrods for those valves. As kinda a rigging setup. I've seen tools you can use to machine down those bosses on the car but don't recommend them myself because of the metal shavings they produce.
