valves sucking oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2002, 10:45 AM
Post valves sucking oil
305 heads on 350 Intake valves sucking oil, pulled intake off puddles of oil laying in intake valves. my first thought was the seals & guides but the more I think about it thats alot of oil do you think its pulling through the intake? any help is appreciated
[ May 25, 2002: Message edited by: wrenchturner ]
[ May 27, 2002: Message edited by: wrenchturner ]</p>
Old 05-25-2002, 03:24 PM
HotRodS10's Avatar
All Throttle...No Bottle
Question
uhhh....and your question was?????
Old 05-27-2002, 04:27 AM
Post
Smoking freight train (wrenchturner)
Old 05-27-2002, 04:42 PM
Post
do a compression test , pull all plugs first, squirt some oil in does compression come up if so
it's rings if not valves, if valves take a piece
of 1/4 inch new cotton rope and bottom each cylinder one at a time push rope in cylinder, leave a little out. by hand rotate crank till rope hits valves, snug tight. now remove valve keeper and springs, replace valve seal. reinstall
springs and keepers move to next cylinder. do same procedure till all eight are done. if engine got extremely hot it comprimises rubber in seals.
I went from 1 qt oil every 100 miles to 1 qt every
1000 miles. hope this helps
