valvetrain oiling issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2010, 04:12 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
hey everyone. i went to adjust my valves the other day and realized the the passenger side bank wasnt getting anywhere near as much oil as the driver side. when i pulled the valve cover off the driver side and started the car the oil was shooting outside the engine bay, where as on the passenger side it was squirting on the rocker fulcrum. also cyl #2 exhaust wasnt getting any oil. i took the pushrod out and cleaned it out and sprayed it with compress air and then tried putting a different rocker arms also. is any of this normal? Thanks
Old 05-25-2010, 04:20 PM
If this is an SBC the chances are the distributor isn't seated properly. It forms part of the pass side lifter galley if it's not setting right it can either plug it or open a leak back to the pan.
Bogie
Old 05-25-2010, 04:24 PM
Listen and Learn
Wiki Edits: 7
Bogie
Yes it is a sbc my apologies. I will check later to make sure that its down in all the way. THanks for the suggestion and the great response time.
Old 05-25-2010, 09:59 PM
fast68's Avatar
likes chevy trucks & boobies
if not the distrib or a gallery plug missing in the block then check pushrods and lifters for any dirt or obstruction in them,.
or in the rocker tip at the pushrod socket
more valvetrain issues keesey1985 Engine 4 05-07-2009 09:16 PM
BBC valvetrain issues njnova Engine 3 07-15-2008 05:04 AM
4.3 v6 valvetrain not oiling chrismac Engine 10 11-22-2007 08:19 AM
Lowering - Camber issues 49lincoln Suspension - Brakes - Steering 1 05-25-2006 12:24 AM
Oiling Issues LilSmoke Engine 7 02-06-2006 04:19 PM
