-   -   Vapor coming fro mthe breather and oil cap but not oil....????? (http://www.hotrodders.com/forum/vapor-coming-fro-mthe-breather-oil-cap-but-not-oil-119330.html)
76 elco 07-03-2007 01:54 PM
Ok so i have a vapor coming out of my breather and my oil fill cap but it's not oil cause it doesn't smel like oil and it is kinda like steam. It's a small block chevy 383 and it runs real strong doesn't get hot and has good oil preasure what could it be and how do i fix it or does it need to be fixed?????? :confused:
Jmark 07-03-2007 02:28 PM
Do you have a PCV valve properly installed in one valve cover? If not, you NEED one. It's most likely a small amount of blow by which is normal. (if there is NO pcv valve)
It's also possible it's steam!! (ouch! not good)
Pull the drain plug on the pan a little and see if any water or antifreeze drips out. If it does, you got problems.
Mark
76 elco 07-03-2007 02:44 PM
Mark
Ya but it doesn't heat up so it's not the head gasket right????? So maybe the intake manifold gaskets????
31choptop 07-03-2007 05:44 PM
it wouldnt necessarily have to heat up or overheat to be a head gasket. it could be either pcv plugged or inop. or water vapor from :eek: ????. check the coolant level!
GCD1962 07-03-2007 06:15 PM
Don't worry, it's probably just normal condensation in the oil pan that is being heated when the car is running and it's venting out the breather
docvette 07-03-2007 07:24 PM
Doc here, :pimp:
ANY running engine will produce some amount of blow~By..I think that is what you are seeing.
IF you don't have a PCV , Install one AND a vented breather cap..It will keep the Engine / Engine Bay cleaner, as well as the undercarriage, and garage floor..the oil will stay cleaner longer.
IF you do have a PCV, inspect it..(Rattle Check it) Then shoot a bunch of carb cleaner through it Be sure it's the right Valve for your Application also.
If it continues , or starts slinging oil, check your valve covers for Baffles, if none, install them.
If it's a FRESH engine the blow~By will settle down over time.
Doc :pimp:
Have a HAPPY and SAFE
4 TH Of July!
glen242 07-05-2007 09:30 PM
76 elco never answered the question on if he had a PCV valve and system installed properly. My guess is NO.
76 elco 07-06-2007 04:24 PM
sorry......ya i don't have one on the motor
Jmark 07-06-2007 04:35 PM
You need one! LOL There should be a 3/8" pipe on the front of the carb just for that. PCV in one cover, vent hose going to the aircleaner in the other.
Mark
