Vapor coming fro mthe breather and oil cap but not oil....????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2007, 01:54 PM
Ok so i have a vapor coming out of my breather and my oil fill cap but it's not oil cause it doesn't smel like oil and it is kinda like steam. It's a small block chevy 383 and it runs real strong doesn't get hot and has good oil preasure what could it be and how do i fix it or does it need to be fixed??????
Old 07-03-2007, 02:28 PM
Jmark's Avatar
Do you have a PCV valve properly installed in one valve cover? If not, you NEED one. It's most likely a small amount of blow by which is normal. (if there is NO pcv valve)
It's also possible it's steam!! (ouch! not good)
Pull the drain plug on the pan a little and see if any water or antifreeze drips out. If it does, you got problems.
Mark
Old 07-03-2007, 02:44 PM
Mark
Ya but it doesn't heat up so it's not the head gasket right????? So maybe the intake manifold gaskets????
Old 07-03-2007, 05:44 PM
it wouldnt necessarily have to heat up or overheat to be a head gasket. it could be either pcv plugged or inop. or water vapor from ????. check the coolant level!
Old 07-03-2007, 06:15 PM
Don't worry, it's probably just normal condensation in the oil pan that is being heated when the car is running and it's venting out the breather
Old 07-03-2007, 07:24 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
ANY running engine will produce some amount of blow~By..I think that is what you are seeing.
IF you don't have a PCV , Install one AND a vented breather cap..It will keep the Engine / Engine Bay cleaner, as well as the undercarriage, and garage floor..the oil will stay cleaner longer.
IF you do have a PCV, inspect it..(Rattle Check it) Then shoot a bunch of carb cleaner through it Be sure it's the right Valve for your Application also.
If it continues , or starts slinging oil, check your valve covers for Baffles, if none, install them.
If it's a FRESH engine the blow~By will settle down over time.
Doc
Have a HAPPY and SAFE
4 TH Of July!
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-05-2007, 09:30 PM
76 elco never answered the question on if he had a PCV valve and system installed properly. My guess is NO.
Old 07-06-2007, 04:24 PM
sorry......ya i don't have one on the motor
Old 07-06-2007, 04:35 PM
Jmark's Avatar
You need one! LOL There should be a 3/8" pipe on the front of the carb just for that. PCV in one cover, vent hose going to the aircleaner in the other.
Mark
Where to find oil breather cap 1964 Oldsmobile 442 Engine 2 03-30-2006 11:53 PM
Mr. Gasket Oil Breather Cap BAD xntrik Engine 5 10-31-2005 08:41 AM
Moisture in oil breather western star Engine 7 12-31-2004 05:30 PM
oil coming out valve breather? Brian Morency Engine 11 10-07-2004 03:50 PM
oil spits out dip stick and breather dosch13@aol.com Engine 5 12-11-2003 05:27 PM
