Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vapor coming fro mthe breather and oil cap but not oil....?????
Old 07-03-2007, 02:44 PM
76 elco 76 elco is offline
Originally Posted by Jmark
Do you have a PCV valve properly installed in one valve cover? If not, you NEED one. It's most likely a small amount of blow by which is normal. (if there is NO pcv valve)
It's also possible it's steam!! (ouch! not good)
Pull the drain plug on the pan a little and see if any water or antifreeze drips out. If it does, you got problems.
Ya but it doesn't heat up so it's not the head gasket right????? So maybe the intake manifold gaskets????
