vapor lock - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2010, 11:22 PM
vapor lock
hi am tom am from butte mt and i have a 55 chevy 4 dr with a 406 small blk and a 6 spd still in finish process and i have a built 54 chevy 5 window with a tuned port 350 i am having a fuel problem i drive it for about 5 min and she starts running out of fuel i have 43 pounds of pre after market regulator i cant enjoy this trk becuse i havent drove it becuse of this problem and when it dies the fuel pressure gauge drops to 0 on the gauge
Old 07-27-2010, 12:28 AM
327NUT's Avatar
Wow!!!! thats all I can say.....no wait, Tom, have you changed the fuel filter lately.
Old 07-27-2010, 12:36 AM
Overdriv's Avatar
Not sure what you got going on, but a few ideas maybe. Tuned port, I'm guessing 82-92 TPI??
If so, the TPI had a fuel pump in the tank and a fuel regulator after the fuel rails, not before.
The unused fuel was sent back to the tank via a separate line.
The TPI fuel system would hold needed fuel pressure on the rails for quite a while after engine was shut off.
A little more detail of the way you have it set up would help.
Old 07-27-2010, 09:56 AM
vapor lock
yes sir it is a 88 tpi motor this what i have it has a in line holley fuel pump and the regulator is after the rail and it dose have a return line to the tank but i do not have any fuel filters installed yet i wouldn't think that would cause my problems
Old 07-27-2010, 06:52 PM
bigdog7373's Avatar
Of course it's fast
can you please use some punctuation. im getting a headache trying to figure out what you're saying.
Old 07-28-2010, 08:41 AM
Overdriv's Avatar
The first thing I would do is check fuel pressure at the rail. Leave your gauge on and take a ride, tape it to the windshield.
With no filters, you could have already trashed the pump. When you use electric pumps, you need a 100 micron filter before the pump and a 10 micron after the pump. Even if your system is new and clean, this is what most of the pump manufacturers recommend.
Old 07-28-2010, 10:05 AM
XNTRCI-T's Avatar
AKA Lee in KC
Montana, being the independent cusses they are, has outlawed speed limits and punctuation. Welcome to Montana, now leave!!
Old 07-28-2010, 12:17 PM
Im afraid it could cause the problem. You may have plugged injectors, very easy to do without filters. If there is a restriction anywhere in the system it will cause the rest of the fuel delivery to be weak and it will run out. That includes the return line, it needs to be larger than the supply line. You need to find the restriction. It could be a pinched supply line, bad regulator, bad fuel pump.
My experience with fuel injection is not with your particular system, but your statement about the regulator being after the rail made me wonder, it that where it is supposed to be? Does that mean there is a regulator on the "return" side? The systems Ive worked on have a wide open return line. I would think the regulator would need to be on the supply side to protect the injectors.
Just ignore the "nunciation police". They are just jealous of your truck..
Old 07-28-2010, 01:28 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by 65smallblock
.... That includes the return line, it needs to be larger than the supply line. ... is that where it is supposed to be? Does that mean there is a regulator on the "return" side? I would think the regulator would need to be on the supply side to protect the injectors.
Nope, on GMs, the supply line is 3/8", the return is 5/16, and the regulator is after the injectors. It returns any volume/pressure above ~43 psi back to the tank. I would suspect the in-line Holley pump, especially if you have no filters in-line to protect it.
