vapor lock? carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2010, 12:22 PM
vapor lock? carb?
We are running a new motor in our 1958 Impala and having problems when temp gets above 180, runs smooth and ok below 180. It seems to be running out of gas or even missing, have to feather the gas to keep it running. When revved up it died and we had to restart back up, but it ran pretty bad after that. When it is cooled down starts and runs great. The weather has been really hot and was not sure if this problem is a heat issue or fuel issue carb or??? Temp never goes above 200 so radiator is doing it's job.
454 bored 30 over with aluminum
demon 750 carb
holly mechanical high flo pump
fuel line is running between the alternator and the block
Any ideas are greatly appreciated. We were down in Reno this last week and it is also pretty hot here 95 out, so we are going to wait until the weather cools down but want to be able to drive even in the hotter weather. It never over heated and ran great as long as the temp was not above 185 or so.
Old 08-15-2010, 12:36 PM
bigdog7373's Avatar
Of course it's fast
Um, that's weird. Maybe the carb is getting to hot. When this happens, try cooling the carb of with some ice something and see if it runs alright afterwards. You may need a spacer.
Old 08-15-2010, 12:56 PM
topwrench's Avatar
Last journal entry: fish carb
I would check the fuel pressure 1st, check it when its cool n leave the gauge in n then when hot.
If that checks out ok you might wanna try what bigdog suggested, I always like to run an insulating spacer between carb and manifold.
Oil in Carb juiced66malibu General Rodding Tech 9 01-04-2010 07:43 AM
Fire in Carb juiced66malibu General Rodding Tech 1 01-02-2010 01:08 AM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
