Vapor lock-New Electric fuel pump. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2010, 03:40 PM
Hi,
1) Can you get a vapor lock using an electric fuel pump?
2) Should i use a pressure regulator with this,its a stock fuel pump?
3) Whats the best way to wire this up,i just have it hooked to the battery for now,temporary?
Any help would be great,thanks.
Old 08-19-2010, 03:59 PM
SSedan64's Avatar
What Pump are you using? Carb, EFI? Vehicle?
You should use a Relay to power the Pump and Ignition or toggle switch to power the Relay.
How to wire relays:
http://www.maliburacing.com/forum/vi...p?f=27&t=41226
Old 08-19-2010, 06:44 PM
bigdog7373's Avatar
Of course it's fast
I also put a fuse in the wire just in case it shorts. Don't want any spark or fires.
electric fuel pump question sexypizzaman Engine 26 05-19-2015 07:13 AM
which electric fuel pump to use? wave1957 Engine 2 07-12-2010 01:21 AM
Wanted: QUIET 12V electric fuel pump for carb'd 350HO Deluxe 38Dodgebiz General Rodding Tech 12 01-01-2010 10:54 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Replacing in tank electric fuel pump scot Hotrodding Basics 6 01-21-2006 01:40 PM
