varijet carburator ???????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2006, 03:02 PM
Last journal entry: ok im on to my next big dream beast
i am using a rechester varijet 2 on my 2.0 gm product i have it mounted and partially tuned but i need to try to find some information on how to tune this carb for more performance and overall driveability i am also at a loss as to where i should run the ignition timing i have set it close but if anybody has put any work into an 2.0 pushrod gm let me know what you did thanks
Old 05-27-2006, 05:42 PM
NorthStar's Avatar
You need to get your hands on Chevrolet Power catalog 6th edition. Oldy but a goodie.
They recommend 31 degrees total timing.
Plus theres lots of other stuff in there too.
http://cgi.ebay.com/ebaymotors/GM-CH...spagenameZWDVW
Old 05-27-2006, 09:23 PM
timing , 2.0
hey thanks just one question is that 31 degrees before or after the advance
Old 05-28-2006, 07:37 AM
NorthStar's Avatar
initial timing + advance curve = total timing
I would start with 10 degrees initial, youre going to need a timing light with retard feature to check total timing.
What are you using for an ignition system?
Old 05-28-2006, 05:30 PM
ignition system
i honestly am not sure but i know the coil is a hotter coil and the ignition module inside the distributer has been up graded and will jump a 6-7 inch spark from the plug wire but other than that i believe it is all stock as far as the ignition system
another question is what determines when the timing advances i know it is not vaccum
Old 05-28-2006, 05:32 PM
carbeurator help
hey guys im still looking for some more information on a rochester varijet 2 any body got some good info i would like to hear it
Carburator Terrano Engine 10 08-07-2004 11:22 AM
edelbrock carburator Charles F. Smith Engine 0 06-17-2004 01:18 PM
carburator? Tissue Engine 6 04-21-2004 03:19 PM
carburator spacer Echofive Engine 10 11-07-2003 07:18 PM
Holley 1850-2 Carburator Forsaken502 Engine 3 09-04-2003 09:43 PM
