Various questions about Fox Mustangs
Have a couple of questions that I'm hoping to get a little help with:
I need to replace the throttle cable on my 88 Mustang GT. The one on now is stretched badly. The car was converted to carb, so the stock cable is made for EFI. My question is, shouldn't a throttle cable for an 85 GT work with no problem?
I'm running the Holley 670 carb(Street Avenger) and the carb is suppose to come with a universal setting, so I thought maybe the previous owner and changed some of the settings because I was never able to get the choke set correctly. I researched a few forums, and several people have said they were never able to get the electric choke set right on their Holley 670 carb and they eventually just took the choke completely off. Has anyone here ever had that problem with the Holley 670? I need the choke because the car is difficult to start.
Last question is how can you distinguish the difference between a car blowing white smoke because it's cold versus there being something wrong internally? I don't start the car often, maybe once a week, or every two weeks. When I start it up, the pipes were e cut right at the muffler, so the exhaust is coming out basically right up under the rear seat. After about two minutes of running, I start to get a lot of white smoke. It's not a thick smoke, but it's noticeable. It seems like I remember the guy I bought it from saying he had put some sea foam in it, but never had a chance to burn it out. So I'm not sure whether it's a combination of the car being cold and sea foam, or I have internal issues any suggestions?
I know I put a lot out there, but I'm trying to get a good start tomorrow on the car and I'm hoping someone will point me in the right direction.
