Vats
Im new and am having some electrical trouble. I am doing an engine swap in a 94 Camaro from a v-6 to a v8 and am having some trouble. the car won't start. I think it could be the VATS deal but i am not sure. I am not using the original key from the v8 should i get a VATS bypass module?
vats
the engine cranks but will not start. i know what vats is and i have just ordered a vats bypass module i will let you know if this works.
If it just restricts fuel then just wire direct power to your fuel pump relay causing it to activate your pump and crank the car over. Should start.
Bringing history and technology together. |
Computer chip restricts the fuel, i dont see how hard wiring the fuel pump to power would fix that?
All you have to do is test the resitance value of the key and get a resistor close to that value and put it inline with the ignition wire. |
vats
the vats bypass did not work i took apart the computer and saw that some resistors had melted together. My computer is obd1 and someone is willing to sell me an obd2 computer for one hundred dollars. will this computer work for my application or is it not compatible. Also the computer needs to be flashed can a dealership do this without the entire car or would i need to connect it to the car and bring the whole thing to get it flashed.
