vatts on a vette - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2011, 02:06 PM
vatts on a vette
how do i trouble shoot the vatts system on a 1986 vette 5.7 engine auto trans
Old 10-16-2011, 02:17 PM
LATECH's Avatar
you will need a mt2500 snap on or tech 1 GM or equivalent, plus the correct software installed in the scanner.
You will need to pull the code and then scrutinize the components involved.
Chances are the trouble is in the key/pellet/lock cylinder contact.
That can be bypassed pretty easily, but scan it first to be sure it isnt a module problem or a wiring problem.
Old 10-16-2011, 04:12 PM
vatts
i know the compoints in the sterring column is working but dont know if the decoder mod is or not
the car does start then dies after 3 seconds
Old 10-16-2011, 05:15 PM
LATECH's Avatar
As posted in the other , I dont think the VATS is the problem as the VATS is supposed to disable the starter from working, and also as mentioned it disables the fuel pump.
It does sound more like a oil pressure switch...possibly or a wiring problem, possibly a broken wire at the Oil pressure switch.Be sure to check all the fuses
406 for my Vette hobby28 Engine 3 01-09-2011 06:51 PM
200-4r into 77 Vette 123pugsy Transmission - Rearend 4 08-23-2009 05:17 AM
new guy - old vette kbyounger Introduce Yourself 5 02-12-2008 08:53 PM
80s vette 350 madhat Engine 5 04-27-2003 03:03 PM
64 vette irs dartman6458 Transmission - Rearend 1 01-01-2003 11:16 AM
