vavle tap i need help!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2010, 07:56 AM
my number 2 valve is tapping i opened the valve cover and saw oil on the valve and also no sign of ware on the valve and it will only tap when i put it in gear and sometimes when the motor is hot what could it be
Old 05-17-2010, 08:07 AM
302 Z28's Avatar
It could be as simple as a rocker arm that needs to be adjusted.
Vince
Old 05-17-2010, 10:29 AM
valve tap
Thanks ill try it
bolt will not thread into hole ran a tap through several times hotbrat Garage - Tools 32 03-23-2010 07:59 PM
tap length tcoop Garage - Tools 9 01-22-2009 06:56 PM
Tap and die pallidin Introduce Yourself 5 09-21-2008 09:12 PM
Motor break in/lifter tap question. RObs71Nova Engine 6 12-15-2004 08:40 AM
tap tap tap elcaminoescondito Engine 3 11-25-2002 05:45 PM
