Vbp-vac - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2010, 02:58 AM
NOlowrider's Avatar
US Navy-Retired
Vbp-vac
Hello-
Another member here (bentwings) turned me on to this little kit that I will need for my blower motor build. Prevents boost from geting to the vacuum modulator on the transmission. Seems like a real simple kit. I think I can build one of these myself and save the $$$. Looking for someone who may have already done it. Seems like a T fitting with a check ball. I think I can take a piece of 3/8 hose and two nipples, put the check ball in the 3/8 tube with some type of device on one end that will not let it seal on vacuum. Once boost is created pshes the ball to the other end wich seals the tube. Sounds easy, right. Or am I missing something. Yea, I know it is a cheap kit, but I think I can make one. What do you guys think? These things are harder to get a picture of than the tooth fairy.
Steve
Old 04-16-2010, 03:09 PM
NOlowrider's Avatar
US Navy-Retired
Anyone? TTT
Old 04-19-2010, 08:57 AM
bentwings's Avatar
bentwings
I don't know why not? I just didn't have the facilities available at the time. Don't forget the orifice.
Old 04-19-2010, 09:03 AM
NOlowrider's Avatar
US Navy-Retired
What size do you think that orifice is?
Steve
Need a new shop vac Irelands child Garage - Tools 10 12-20-2008 03:40 PM
swapping in a chevette vac booster HELP!!! ajbcc2 Suspension - Brakes - Steering 1 08-03-2008 07:04 AM
Vacuum advance not active at cruise (port vac source) - help hotrodf1 Engine 21 06-25-2007 03:50 PM
Timing advance issues... autonuerotic Engine 27 11-22-2006 06:51 PM
Timed Vac Port or Manifold Vac Port Sweet-34 Electrical 14 04-27-2004 04:35 AM
