vc breather smoking sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2010, 01:42 PM
using a set of edelbrock signature series (1 hole in each) on a sbc 305, driver side pcv valve, pass. side open breather.... what causes "blow by" or smoke to exit out of the breather? Just curious....
Old 12-23-2010, 03:39 PM
Blow by which is the gases of combustion escaping around the piston. The PCV should be picking all of this up at idle so there should not be smoke emitting from the inlet side till the throttle is mostly open which causes a situation where these a lot of blow by into the crankcase and not much manifold vacuum to drawn it off through the PCV valve. If it's smoking a lot at idle this is either a failure of some sort in the PCV system , usually the valve but not always. The worst case situation is where the rings and or cylinder walls are worn out or damaged resulting in excessive blow by.
Bogie
Oil breather cap viking Engine 28 03-14-2008 02:46 PM
pcv with and without breather curtis73 Engine 3 01-12-2008 02:06 AM
PCV value or Breather juiced66malibu Engine 3 11-07-2007 01:39 AM
breather/pvc brickhead Engine 1 12-25-2006 12:25 AM
breather Bob88 Engine 1 06-21-2003 11:37 PM
