VDO Electronic Speedo not working. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2011, 07:23 PM
I think this may me a electical issue.
Hi, after yrs of playing with muscle cars and classic cars, my wife and i decided to get a street rod. Its a 41 Chrysler Business Coupe with a 37 Chevy nose on it. It has Chevy running gear and electrics too, 350/350 10 bolt.
I have tried to contact the original owner to see what he used for the build but cant find him, the shop that built the car (2003) cant find the records either.
Anyway, it has a VDO Gauge set, it looks like they may have come all together, they are white faced retro looking gauges, Volts, Temp, Oil, Speedo, and Fuel.
The Speedo has a needle that goes to 120mph and has a LCD odometer. It does nothing, either when driving or turning the key etc.
Not sure how these work or where it gets its info from, can someone point me in the right place? I assume there is a control unit somewhere either on a axle or in the distributer that caculates something.
Old 04-12-2011, 07:38 PM
BOBCRMAN@aol.com's Avatar
The unit gets signal from the speedo gear. There are two different types of speedo and of course two different senders.
I bought a complete set of VDO guages at a swap meet for dirt cheap one time. Then had to learn the different senders. Once figured out. A nice set.
Jegs had the speedo sender. VDO has specs and a download for instructions
VDO North America 188 Brooks Rd. PO box 2897 Winchester VA. 22603 540 665 2428..
I found the file.. Amazing!!! If you will PM me with your e-mail. I will send you a copy of the speedo information and charts.. Bob..
Old 04-13-2011, 06:00 AM
Irelands child's Avatar
Same info CHR gave you plus a couple more:
http://www.egauges.com/pdf/vdo/0-515-012-178.pdf
http://www.egauges.com/pdf/vdo/0-515-012-051.pdf
OR
Wiring a T-5 (Electronic) to a new speedo 40pickup Transmission - Rearend 0 09-09-2008 06:45 PM
electronic speedo wiring sparkyct55 Electrical 1 07-23-2008 02:34 PM
Retrofit an electronic speedo? BillyJoe Electrical 2 12-06-2004 03:53 PM
Retrofitting an electronic speedo?? BillyJoe Transmission - Rearend 3 12-04-2004 10:51 AM
Electronic speedo Shortstep Transmission - Rearend 0 08-25-2003 08:23 PM
