VDO programmable speedo with 700r4
I'm working on my brother in laws 57 chev truck that I've installed a sbc and 700r4 into. His boys got him a set of VDO gauges for it for Xmas. I told them what we were working with before they bought the gauge kit but I want to make sure this speedo is right before I start hooking it up. I have no confidence in the guy that my nephews ordered the kit from. He gets a lot of stuff wrong.
The 700r4 is originally out of an 88 V6 Astro and it has one of those GM ratio adapters on it that slows the speedo cable down 26.7%. I'm wondering if I should take it off, leave it on or does it really matter? The VDO kit came with a hall effect sensor to run the speedo. There's no part number on it or the box but there's a sticker on the wire attached to it that says V1511010056A. Are there different sensors for different trannys? I want to make sure this one is correct. |
vdo guages
hi,go to the vdo.com web site.they should be able to answer your questions.
no VDO site for their gauges
I went to the VDO Seimans site. I don't think they have any info there on their automotive gauges. I think they leave it up to their vendors to supply info on their custom automotive gauges, which is too bad because all the sites I visited did a poor job of covering their gauges.
I'm in Brandon. You must be near Virden.
The hall effect sensor they sent just screws onto the tranny where the speedo cable normally goes and then there's wires coming off of it that go to the speedo. I've probably got the right one but I got nervous when one site I saw said there are 4 different sensors you can buy. Maybe the different sensors have different threads for different makes of tranny? |
| 700r4 speedo question | Jmark | Transmission - Rearend | 2 | 10-08-2006 08:33 PM |
| 700r4 outer speedo gear not turning? | John Fabris | Transmission - Rearend | 8 | 05-13-2006 11:43 AM |
| Need advice: 700R4 banging in 1st | 360Camaro | Transmission - Rearend | 11 | 11-20-2003 06:44 PM |
| 700R4, cruise & electronic speedo | 302 Z28 | Transmission - Rearend | 10 | 10-31-2003 12:28 PM |
| 92' 700r4 to th350 swap speedo problem | Gojo | Transmission - Rearend | 1 | 09-30-2003 10:11 PM |
