vega auto trans tail-housing interchang w/th350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2010, 05:50 PM
I have a vega auto trans, not shure what its called. It has no cooler and air holes in the bell housing. question is I need a tailhousing for a th350 and it looks like it might be the same? any input appreciated.
Old 03-01-2010, 10:18 PM
junior stocker's Avatar
It's probaly a TH250 in a Vega, but the extension housing should change out, as long as they're the same lenth. The Vega TH350 extension housing probably has a boss on the underside for the anti-vibration weight. You could also use the Vega converter for a little higher stall.
Old 03-02-2010, 12:15 AM
if your lookin for tailpiece for a vega/monza with torque arm mount there was 2 on ebay a few days ago
Old 03-02-2010, 02:41 AM
Wiki Edits: 85
If the Vega housing is held on with 4 bolts and is 6" long it will work on any other TH250/TH350 transmission needing the same length tail.
Tail Shaft Housing...Long or Short??? lt1_performance Transmission - Rearend 4 07-11-2007 10:14 PM
trans bell housing on 66 mustang gun70runner Engine 4 01-25-2006 01:19 AM
th350 tail shaft / extension housing switch 72BuickGS350Conv Transmission - Rearend 2 10-23-2005 08:34 PM
GM Auto trans identification help? Pantera II Transmission - Rearend 1 12-02-2002 04:02 PM
