vega box problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2012, 12:27 PM
vega box problems
I also am new to hotrod forum. I am having problems with my vega steering box on 32 ford coupe. After driving for a few minutes it seems as though it has a stiff spot in steering as though it is slightly stuck. Anyone else with this problem. Could it be box or column
Old 07-15-2012, 08:52 AM
Ive run into this problem several time actually either the check valve is sticking on you or your pump is dropping pressure after warm up or your fluid is overheating ps fluid looses its vescosity at around 120 deg., synthetic fluids have much higher vescosity rates but in most cases are not required
Old 07-15-2012, 12:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I've never seen a power Vega Steering box. So I guess this is a manual steering box?
I would check the adjustments of the box, steering U-joints. If the box is near the engine, it must getting warmed up by engine heat
Old 07-15-2012, 06:20 PM
Actually, its not a power steering box.
Old 07-16-2012, 04:02 PM
Oh well, in that case your steering shaft is binding up or you have a worn worm gear, and flaming river offers a power steering vega box by the way.
Vega Box or Reverse Corvair Box? Ltlgto Suspension - Brakes - Steering 9 04-24-2008 05:02 PM
Vega box upside down? cboy Suspension - Brakes - Steering 17 07-18-2007 08:32 AM
Vega Steering Box MARKDEB Suspension - Brakes - Steering 2 12-22-2004 05:27 AM
Vega box location Lee Hulick Suspension - Brakes - Steering 2 10-26-2004 09:40 AM
Vega steering box Mike Weaver Suspension - Brakes - Steering 1 07-08-2003 07:28 AM
