Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vega Box or Reverse Corvair Box?
Old 04-23-2008, 11:21 PM
Centerline Centerline is offline
Wiki Edits: 49
I'm using a GM small manual box in my deuce. Mounts the same as the Vega unit and is pretty much the same size just a bit heavier. Picked it up at a swap meet for $15.
Here's a Vega box...
And here's a Nova box....
As you can see the only real difference is the length of the input shaft (its about 6") which in most cases shouldn't be a problem.
