Vega Bracket car: Disappointing ETs...down on power from where it should be... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-22-2012, 06:25 PM
Richiehd's Avatar
JS-70
Facinating read from everyone. Been 30 years or more since I drag raced. Just curious what does "back halfing" mean? sorry to break up the thread.
  #17 (permalink)
Old 05-22-2012, 10:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Very briefly it's installing a different rear end suspension (and often a different rear end and housing), and crossmembers, etc. to help handling and/or traction. It may be a 4-link, or ladder bar (shown), or some other set-up. Usually includes a roll bar or cage to tie the chassis together along w/connections between the front and rear on cars with subframes/unibodies.
  #18 (permalink)
Old 05-23-2012, 06:49 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by cobalt327
Any reason you're not using a transbrake? If your not traction limited it'll help the 60' and that helps the ET more than just the reduction in 60' time...
Yeah, money,
I just replaced the trans with one that has a TCI reverse manual VB and all good clutches and stuff, got it for a little more than I was planning on spending for a manual VB and a deep pan, and it has both. The TCI trans I was running before has had chronic leaks, and running an JW UltraBell, the pump bolts don't seem to want to stay tight. As I get time and money, I am going to go through that trans, replace the case if necessary, and build it for a brake. Finding sponsorship would speed up a lot of these plans, and I've got some folks interested in doing so, but "the time isn't quite right just yet".
If you do not want to register, fill this field only and the name will be used as user name for your post.
power steering bracket zoomo Engine 7 09-12-2010 08:34 AM
Please Help!power Steering Bracket cutthroatkid Engine 1 12-24-2009 01:00 AM
power steering bracket tinman386 Engine 6 02-01-2007 10:23 PM
Power steering bracket asportsman Engine 1 01-16-2006 12:34 PM
power steering bracket soad777 Engine 0 09-14-2003 09:17 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
