Vega rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2010, 10:17 PM
Vega rear
I have a '74 Vega, I'm trying to find out what kind of rear axle it has, It has 11 bolts, Torque arm, panhard bar, and torsion bars, Like the setup on F-bodies.
Old 11-11-2010, 10:21 PM
ericnova72's Avatar
More for Less Racer
Are you sure of the 11 bolt count?? Can you post a picture of it from the rear??
Old 11-11-2010, 10:30 PM
big gear head's Avatar
High Performance Rear Ends
Did you check this link from your other thread? http://forums.h-body.org/index.php
Old 11-12-2010, 11:10 AM
It's '74 Vega Panel Wagon, 10-bolt, but with torque arm, torsion bars, and panhard bar, Like a F-body?
Old 11-12-2010, 02:44 PM
ericnova72's Avatar
More for Less Racer
The '74 and newer Vega has the torque arm suspension stock, pretty much the same as the Monza has, only the '71-73 Vega's have the 4-link type. Yours also has the typical weak 7.5" 10-bolt stock.
Old 11-12-2010, 08:25 PM
Using the torque arm set-up, What would be the cheapest way to make it stronger? We are on a budget! Thank You
Old 11-12-2010, 08:35 PM
Does the torque arm bolt up exactly like the 3rd and 4th gen Camaro rear end? If it does then narrow a '90 or later Camaro 7 5/8 rear end to fit the Vega. The '90 and later 7 5/8 has 28 spline axles, better differential and usually nice PBR disc brakes that you might want to use.
Old 11-12-2010, 10:40 PM
ericnova72's Avatar
More for Less Racer
How much power do you intend to put to it, and how good are you going to try to hook it to the pavement??
Big Gear head has given you some idea with the later F-car rear but it will be a problem over 400hp if you try to hook it on slicks. A 9" Ford, 8.8" Ford, 8.5" GM 10-bolt, Jeep Dana 44 would all require custom fabrication for the torque arm mount and narrowing to install but are much stronger.
A really cheap upgrade would be 88-newer S-10 28 spline axles and corresponding 28 spline posi or mini spool (depending on your intended use) into the stock 7.5" housing, figure 350hp to be its limit.
Old 11-13-2010, 07:31 PM
Would the S-10 axles fit the axle housing that is already on the Vega and use the torque arm set-up? The car will have somewhere between 3 to 400 horse, any more would look at 8.8 Ford rear. Thank You for your time.
Old 11-13-2010, 08:57 PM
ericnova72's Avatar
More for Less Racer
I think it will, from what I have heard, but verify this elsewhere rather than take my word for it. I have two Vega's but both don't have the stock suspension or rear axle any more, I knew better than to try and use that weak stuff.
Try asking at the H-body forum, they are more into stock suspension than I am. Mine both have 8.5" rears in them, one is drag race 4-link and one is modified truck-arm style.
Old 11-14-2010, 04:38 AM
jon72vega's Avatar
WOW, I could have had a V8!
As ericnova72 said, join up & ask these questions at the H-body message board.
There are many knowledgeable members there.
Jon
http://1972vega.wordpress.com/
1964 Impala SS Hood Adjustment 64Joker Body - Exterior 4 04-13-2008 10:11 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
