Vega rear end, what will fit in a vega - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2006, 12:53 PM
Hello
I have a 1972 vega, i have a sub-frame built, and i would like to know what other rear end will fit in a vega that is stronger than the originall rear axel. I am putting in a 350.
Or if anyone knows the width of the rear axel that would be good to know also.
Thanx
Last edited by M&M CUSTOM; 04-02-2006 at 02:59 PM. Reason: Removed e-mail address, sent PM explaining why.
Old 04-02-2006, 02:13 PM
Race The Truck
Last journal entry: Son's Truck
I know there use to be a kit for the vega. Its been so long from high school but I belive the monza and there was one other car that came with a v8 in it but can't remember.
Craig
Old 04-02-2006, 02:56 PM
1964fordtripower's Avatar
I ran a 327 4 speed vega for years, after blowing up the 3rd Vega rear end, I stuffed an 8" Ford rear end from a Maverick under it. It of course wasn't bolt in, all the brackets from the Vega rear end were transfered from the Vega unit and a hibred drive shaft was built.
Old 04-02-2006, 02:58 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Monza, Vega, Olds-Starfire, and a couple others but I only remember those three off the top of my head.
Old 04-03-2006, 03:37 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
If I remember correctly a dana 44 from a jeep can be made to work pretty easy.
Old 04-03-2006, 03:42 PM
poncho62's Avatar
Wiki Edits: 5
Originally Posted by vegakid
Hello
Thanx
If you had a subframe built, you might as well get a 9 in Ford rear shortened up to fit that. Then, you know that you have a good strong rear for it. Get whatever wheels and tires you want to run too, so you can get it shortened to the proper width.
Old 04-21-2009, 12:16 AM
i have a fix. the postal jeep dana 44 comes with a trac-loc posi,it measures 52''
the rear end i got has a 8.5 '' gear ratios from2.73 to 5.38 they make two possies, a trac lock(work of tire speed difference) and a power loc(the more power you put to it the more locked it gets) the rearend comes from pj's postal jeeps ther 52" wide and have 30 spline 1.25 axel shafts.remove your stock axel mounts from the axel and tranfer them to the dana 44, the jeep axel has 11"" rear brakes that shuold work with s-10 front. I have pushed a 3450 car on a dana 44 with 35 '' tires and itwas almost tough enough(snap an axel every year or so) I got mine at a junk yard for $23.50 so that my idea.good luck
Old 04-21-2009, 12:48 AM
One of the vega's I built had bolt in sub frames under the car. Narrowed large pinion 10 bolt with ladder bars for the street. Did not have tubs in it. Ran G60 Caldwell's for bite. Would pull the front end with a mild 327.
I've also used 8.75 chrysler, Dana 60, Ford 8" and ford 9". All of those we had to cut down thou.
You might also look at the factory V8 Vega, monza rear ends, but you will have to add the upper control arms if you're wanting to remain stock.
A ladder bar type suspension can be seen in a couple of pics at www.photobucket.com/v8courier
Old 04-21-2009, 02:57 PM
HawkMonster's Avatar
Imagination bigger than wallet
If what you remember is true, and you're talking about 87 and newer jeep D44's, then a ford 8.8 would be just as easy, or easier, and can be found with disc brakes, posi, and an assortment of ratios from 3.08-4.10 (or 4.11, I don't remember). I've got the 8.8/4.56/disc/electric locker swapped into my Cherokee, and I bought one with 3.73/posi/disc brakes for $100 to swap into a small truck project I'm building.
The 96 and newer explorer ones are the ones with larger 31 spline shafts and disk brakes. If you get one out of anything else, it'll have the weaker shafts.
On edit-They'll have a 5 on 4.5 bolt pattern.
Old 04-21-2009, 04:31 PM
The Monza/Starfire/Sunbird/Skyhawk used a torque arm suspension. The original Vega suspension was a four link. Good luck finding any of those today.
Old 04-21-2009, 06:11 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Thanks for the clarification, even though my post was just over 3 years ago.
Old 04-21-2009, 10:26 PM
vega rear end
The rear end I am describing is a postal jeep rear axel 52" wheel to wheel, no cutting is required, most are limited slip(track-loc)and are3.73 or 3.08 geared,they have 11" brakes and 30spline axels. as far as 4=lil brackets go a plasma and a find hand can do it from the stock rear,of course you'll wan to box them ...
Old 04-28-2009, 09:32 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I'm 99% sure ALL the explorer differentials have 31spline axles, they are approx 59.75" across wheel mounting surfaces.
Also the early broncos (up to 1977 I think) had a 9" rear that was 58" across drums. (but only 28 spline axles, you would want to upgrade to 31 probably, which you can get from suppliers like completeoffroad). A problem is the wheel bolt pattern is 5x5.5"
Both the explorer and bronco axles were available with good gears also. (bronco with a 302 had 3.50 standard with 4.11 optional, 6cyl had 4.11 std 4.56 option).
Old 04-28-2009, 12:14 PM
I should've been clearer, yes all explorers have the 31 spl shafts, but in 96 or 97 (I forgot exactly which year) they started putting disc brakes on them, that's why I was mentioning the later years being more useful.
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
38 Dodge rear end dwayne_tn Transmission - Rearend 5 09-09-2005 09:35 PM
s-10 rear end smallblocked_S-10 Transmission - Rearend 11 06-17-2005 05:43 PM
will a 4th gen camaro rear end fit 3rd gen? 84Z Transmission - Rearend 2 05-13-2004 07:51 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
