Vega steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2002, 02:52 PM
Post Vega steering
I'm about to change to Vega cross steering on my 32. I bought the weld on frame bracket for the box but I'm not sure were to mount it.Do you get the tie rod and drag link paralell and mount it there.I could really use some help on this project.Thanks
Old 12-06-2002, 03:39 PM
deuceguy's Avatar
Post
That's how I did mine. Just make sure your pitman arm is in the center of its travel, that is, sticking straight out. Clamp the bracket in place and mount your box, and turn the pitman arm through it full arc to make sure everything moves OK and nothing binds, bumps into anything else,etc. Then weld er up. Good Luck.
Old 12-07-2002, 04:50 AM
Post
Thanks for the input Deuceguy.Is that your Deuce in the picture?......Lash
Old 12-07-2002, 07:46 AM
Post
I bought a aftermarket arm for my Vega box. It is shorter than OEM. Slowed the quickness down. Plus is is stainless and shiny. It goes with the rest of the shiney front end....
:p :p
Old 12-07-2002, 11:22 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Shiny is good!!
Old 12-07-2002, 12:53 PM
deuceguy's Avatar
Post
Lash, yes that's my deuce. couple of more pics in my photo album. Post pics of yours if you got em.
