vega steering box on a 1930 model a frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 12:12 AM
mounting info for a vega box going on a model a frame , it has a new axel w/ mono leaf spring thanks Dave.
Old 01-22-2006, 08:48 AM
The Model A frame needs to be boxed in the mounting area. A bracket and a gusset are needed to mount the Vega.
I always install a Vega just ahead of the left motor mount with the bracket level with the top of the frame. I suggest you just tack the bracket and install the box and check for fit and interference.
Old 01-22-2006, 08:14 PM
milner's Avatar
also depending if you are using cross steering or drag link type, you might have to reverse the worm shaft in the steering box.
Power steering pump hitting box tjh211 Suspension - Brakes - Steering 7 11-16-2004 04:29 PM
Power Brakes for 52 chev car Looking for a steering box that will work Michael Bryan Suspension - Brakes - Steering 0 03-29-2004 07:22 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Model a steering jforward Suspension - Brakes - Steering 4 08-27-2002 05:43 PM
model a/vega steering box jvarble Suspension - Brakes - Steering 5 01-11-2002 07:41 AM
