Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vega Steering Box
Old 09-28-2005, 10:06 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Vega Steering Box
My latest project ('30 Ford Coupe) came with a Vega steering box installed to the frame rails. I got to looking at it and other than the cap screws and adjuster screw, I don't see any provision to check/fill the box with gear oil. I've looked at other Vega steering boxes and they all seem to be the same configuration.
How do you check the gear lube? What weight gear lube is used?
Thanks in advance.
