Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vega Steering Box
Old 09-28-2005, 05:17 PM
sedan delivery's Avatar
sedan delivery sedan delivery is offline
gear box
one of the bolts that hold the pitman arm shaft adjustment cover goes into the gear box for filling. remove one of the bolts one at a time and insert a wire or smilier thing into the hole and see if goes though. when it does use a small funnel and add 90W gear oil to the gear box. it is a slow process because of the small hole. take your time , it will be messy. you might want to check web sights and search out for the amount to add. just type vega gear box, and see what come up.
