vega steering box and pitman arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2012, 09:41 PM
Where do most people mount there steering box on a original model a frame to clear the motor mount I have a tubular from speedway I mounted 12 inches back from my spring crossmember any suggestions on where and if I could get a smaller pitman arm I think that would help with clearence from the tie rod
Old 03-13-2012, 07:08 AM
BOBCRMAN@aol.com's Avatar
Speedway used to sell Vega/Monza arms. Screws up steering ratio with shorter arm. Mount steering box between engine mount and axle. Cross steer with steering rod almost parallel to axle/tie rods.
Mustang steering - pitman arm angle user151 Suspension - Brakes - Steering 4 05-21-2009 02:13 PM
bending a Vega pitman arm Slomotion34 Suspension - Brakes - Steering 29 08-01-2008 08:05 AM
vega steering pitman arm question 29modela Suspension - Brakes - Steering 2 11-02-2006 11:09 AM
vega pitman arm 31fordrd Suspension - Brakes - Steering 1 10-03-2003 08:34 PM
Vega pitman arm Lash Suspension - Brakes - Steering 1 01-10-2003 04:07 PM
