Vega Steering Box Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2011, 08:54 AM
Jim7231's Avatar
I just replaced my old Vega box with a new one. The new box has the typical center stiff spot, however, the steering over all is stiff and when driving the steering does not come back to center without steering back to center. Everything seems to be free but the box seems tight. Do new ones typically need breaking in?
Old 07-18-2011, 10:14 AM
Wiki Edits: 27
re adjust,
You might need to back out the adjusting screw for a few hundred miles then reset. todays quality might not be as good or where was it manufactured makes had a difference.
Old 07-18-2011, 10:31 AM
Jim7231's Avatar
Vega box answer
Thanks for the reply. I'm not sure where this was manufactured, but it's a good guess it might be off shore. I'll see if I can get it to loosen a bit.
vega steering box question jaredyocum Hotrodding Basics 2 05-31-2007 07:43 AM
vega steering pitman arm question 29modela Suspension - Brakes - Steering 2 11-02-2006 11:09 AM
Vega Steering Box Frisco Suspension - Brakes - Steering 2 09-29-2005 08:14 AM
Vega steering box Mike Weaver Suspension - Brakes - Steering 1 07-08-2003 07:28 AM
Vega steering Lash Suspension - Brakes - Steering 5 12-07-2002 12:53 PM
