Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vega steering box stiff to rotate
Old 05-28-2006, 08:05 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
There is nothing wrong with that box, That hard spot is supposed to be there.
That "tightness" is what helps keep your car from wandering when you are going in a straight line. That is why it is important to set up your steering linkage so that the box is centered.
There is actually a torque value in the book, (I have a factory manual for a vega, how weird is that?), that specifies the amount of torque to pull the steering wheel over the center. If I remember correctly the value is 8-16 INCH pounds max @ the steering wheel with the pitman arm removed. The same value with the steering gear removed is supposed to be 7-8 inch lbs (including thrust bearing preload of 4 in-lbs) . The torque is supposed to be measured with a dial type torque wrench of no more than 50 inch lbs. Try finding one of those LOL.
On a used box I would not set it that tight. I will post up the procedure if you want.
If I were you I would leave it alone unless it is extra tight or really loose.
Hope this helps, mikey
BE different....ACT normal.
