Vega steering in a model a ford
No matter what I try i can't make the vega steering box fit with chevy motor mount. What's best fix? Can I move the box in away from the frame? Change mounts? I need help.
Thanks daveynuts&bolts. |
If your doing cross steering... You can mount the box right in front of the motor mount's.. If your using the side motor mount's...
Post a picture of what you have,,Then we maybe able to help you better.. |
Here's a typical Model A chassis with the vega cross steer setup. These photos may help. In the first you can see the vega box installed and in the second you can see typical SBC motor mounts and where the vega bracket is in relation to them.
Good luck. ![]() Centerline HotRodsAndHemis.com “If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates |
Here's a Vega box with a 327 in my Model A. The frame rails are not stock Model A, so this may or may not work for you.
| ford transit 2000 model steering biased 1 way | jstott85@yahoo.co.uk | Suspension - Brakes - Steering | 4 | 06-26-2009 08:25 AM |
| Vega steering box | retsub | Suspension - Brakes - Steering | 2 | 04-18-2007 06:47 PM |
| vega steering box on a 1930 model a frame | David G | Suspension - Brakes - Steering | 2 | 01-22-2006 08:14 PM |
| Model A Vega Steering | loiselle | Suspension - Brakes - Steering | 1 | 02-10-2004 07:53 AM |
| model a/vega steering box | jvarble | Suspension - Brakes - Steering | 5 | 01-11-2002 07:41 AM |
