vehicle ID numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 07:58 PM
vehicle ID numbers
I have a 1970 Nova and I'm trying to figure out if it is a true SS. I have found 2 sets of ID numbers that are both the same. One set is in the engine compartment by the brake fluid holder, the other is on the top of the dash, drivers side, you can see it when you look through the front window. The numbers start with 11427. From what I have seen, the SS numbers have letters in them, like 1x27k. is there another set of numbers somewhere?
Old 03-28-2006, 11:16 PM
The 1X27K only applies to the '72 Nova. The K denotes the 350/4-bbl engine, which was only available in the SS in '72. There is no way to tell by the VIN on a '70. You might look under the seats and see if there's still a build sheet in it. I don't know if that will tell you, but it might.
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 07:33 AM
vehicle ID numbers rick6160 Body - Exterior 1 03-28-2006 07:43 PM
emision loopholes digitalfrek Engine 13 03-13-2006 07:25 PM
tryin to figure out the weight of truck 5.7s10 Hotrodding Basics 6 01-14-2006 09:40 AM
Vehicle Identification Numbers Bobby O'Brien General Rodding Tech 3 11-13-2005 12:22 PM
