Vent window weathersripping - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2007, 08:50 PM
I'm frustrated as hell. I'm trying to install new rubber on my vent windows in my truck. I bought good quality rubber from Dennis Carpenter. It kinks up about an inch and a half when I get to the end. Do I have to cut it to make it fit? See pic.......
Old 07-07-2007, 09:00 PM
adtkart@aol.com
You should not need to cut that. Try lubricating the thing to make sure it is going all the way into the channel. Usually, when I install a seal that does that, I will remove it enough to go opposite the way I had originally started. Sometimes that is all it takes.
Aaron
Old 07-07-2007, 09:06 PM
Would you use soapy water? or something else?
Old 07-07-2007, 09:27 PM
excaliberprime's Avatar
Last journal entry: back for 2014
i always use a stick of zipper ease its real thick so it will not run and keeps moisture from getting under your seals. its normaly used to lubricate zippers on tents and can usualy be found in the sporting goods section.
Window channels and removing vent window Jackyl Interior 11 10-10-2007 08:01 AM
vent window removal codeman Hotrodding Basics 9 03-12-2007 09:12 AM
Adjusting Vent Window on 1939 GM Body JohnTN Interior 1 09-30-2006 10:25 AM
Removing vent window on '58? Nanook Body - Exterior 3 01-09-2005 07:06 PM
72 chevelle vent window parts? 73chevyhelp Body - Exterior 2 04-07-2004 04:55 PM
