-   -   vent windows (http://www.hotrodders.com/forum/vent-windows-213445.html)
cherry540 01-28-2012 09:09 AM
vent windows
Want to remove the vent windows from my 54 chevy truck. Got the run channels and glass figured out. How do i make the beaded window seals along the top of door. work. Can order a set for a 50 witch had solid widow?
Houston54 01-31-2012 02:41 PM
I like the vents in my 54. Here is the rebuild sequence I documented when I did my 54 vent windows. It is so easy you might want to keep yours.
http://www.stovebolt.com/techtips/wi...ild/index.html
Trying to make the 54 doors into one piece glass style doors is not impossible but does require significant effort. Here is a write up one of the truck rags did some time back on one of these trucks.
http://www.customclassictrucks.com/t...regulator.html
nine4gmc 01-31-2012 04:51 PM
that one piece is soooo smooooth! lil bit of work but the results speak for themselves!
cherry540 01-31-2012 07:08 PM
yea I like the vent windows too mine are too far gone to rebuild I was trying to save the almost 600 to get new ones. Thanks for the info Ron
evolvo 01-31-2012 11:10 PM
http://www.restorationspecialties.com/
These guys are great! Here is the catalog. Scroll down on the left side till you find "Street Rod Channel Kit" and click on the green thingy!
http://www.restorationspecialties.co...og%20ebook.pdf
