vertical holes in 2x4" frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2013, 08:35 AM
Last journal entry: 27
i need to drill four 1/2" holes all the way through my 2x4 frame
top to bottom.
there will be bolts going through to hold the cab of my truck to the frame.
will that weaken my frame considerably?
Old 02-28-2013, 08:42 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You can do that..make the hole oversize and then place a 1/2 inch ID tube in the hole that goes all the way through so you do not crush the tube when you torque the bolts. that is a small overlooked detail when bolting things to tubing.
Sam
Old 02-28-2013, 08:56 AM
to spread the load of the tight bolts.
i have these plates that are 2" x about 6" 1/4 inch thick steel i am using for washers
Old 02-28-2013, 09:02 AM
jaw22w's Avatar
Welding in the sleeve also puts the strength back in the 2x4 tube. Can't you weld a bracket to the side of the 2x4 and bolt to that. It would be a better solution.
Old 02-28-2013, 12:13 PM
model-a's Avatar
Last journal entry: tools
x2 on what onemoretime said.
Old 02-28-2013, 04:00 PM
1971BB427's Avatar
I'd personally rather have a tab welded on the side of the frame also, like jaw22w mentioned. Not that going through will weaken the frame, but I like brackets and shorter bolts for strength.
Old 02-28-2013, 05:07 PM
life is a temporary assignment
You have to weld in a sleeve to do it the right way,,, If you don't weld in the sleeve, The bolt will never stay tight, Plus you will crush the tubing when you tighten the bolt.. Why not make some body mounts and weld them to the side of the frame with a nut welded to them... Here's some I always make..Thes are very easy to make out of a piece of tubing..
ID:	71877   Click image for larger version
Old 02-28-2013, 08:54 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
..To New Interior & 71BB427 ,i use these i made from 2x6 then trim bottom off as to not come to a sharp point, Also these welded to frame will add strength ,Not weaken them like driiing, Just my opimion,and you know what opinions are like,.LOL
Old 03-01-2013, 12:01 AM
zmaxmotorsports's Avatar
I was always told to avoid welding vertically on a frame if at all possible anyway because it weakens the frame,or maybe that's just on channel type frame rails.
If you want to mount the mounts on outside of frame I suppose you could drill and mount the sleeves from side to side through frame,of course that's more holes to drill
Old 03-01-2013, 01:55 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Yeah and that lazier level is key.The frame as a ref has to be totally level before you do anything.
Old 03-01-2013, 06:27 AM
Wiki Edits: 27
another option
First why 4 bolts? factory mounts usually only have 1 bolt. I like new interiors style mounts best. When I have to mount something to the frame, I grind off any cad-galvanized plating. I haven't used muratic acid dip yet to remove the coating. I used a uni-bit , the cone style cutter to open up the hole for a hammer press fit. and it chamfers it for welding, I install a nut and washer to the bolt and tap it in place and square up the bolt. Tack weld then remove the bolt -washer and finish weld, tig is best, then if needed grind flush and run a tap thru the holes.
drilling holes in frame for the T-400 0trbo4myCHEVUICK Transmission - Rearend 16 08-04-2012 05:52 PM
Filling 1/8" trim screw holes. Question novafreek6872 Body - Exterior 11 04-21-2012 06:12 PM
Plugging holes in 32 frame rails heyjude076 General Rodding Tech 5 01-25-2007 08:00 AM
best way to fill in frame holes jimmy p General Rodding Tech 2 10-30-2003 04:57 PM
