Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Very Hard Braking!
Old 07-02-2011, 11:31 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If the booster is working properly and your pedal ratio isn't way out of whack, the problem is most likely too large of a bore on the master cylinder.
Just curious, do you have a combination valve or seperate residual pressure valves and a metering valve? If the valves are seperate, do you have a proportioning valve?
Andy
