Very high oil pressure causing leaks - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 07-18-2013, 12:51 PM
Project89's Avatar
Originally Posted by Pupsvette76 View Post
ok so if i removed the crankcase evac kit and used a PCV system how would that would this is a turbo car would the boost in the manifold plumbed to the PCV valve force the valve to close at WOT when i actually need the PCV valve to operate the most
here is how i run mine , pcv valve hooked up like normal in the driver side valve cover( with a check valve), then i weld an an fitting in the passenger cover inplace of the breather hole , this line attaches to a catch can i made , the line attaches in the middle of the can, on the top of the can is another line that attaches to my compressor inlet , this sytem works great
the top line on the can attaches to the air filter pipe on the turbo inlet
pcv operates normally under non boost contditions, and under boost the pcv is closed and the line attached to the turbo inlet takes over
edit
the reason the line off the valve cover is in the middle of the catch can is when there is suction if oil comes out of the valve cover , when the air/oil mix enters the can the air goes up and the oil droplets fall into the bottom of the can,if the lines are across from each other or nexto each other in the can , u will get oil in the turbo compressor side and cold pipes
  #47 (permalink)
Old 07-18-2013, 01:27 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
Does an oil pressure sender use its threading to ground and complete a circuit because I have mine threads into a brass adapter which both sets of threads have sealer on them possible effecting a ground
  #48 (permalink)
Old 07-18-2013, 02:29 PM
delawarebill's Avatar
sending unit
yes it does.. u may want to pull it and just use one rap of teflon tape.
  #49 (permalink)
Old 07-18-2013, 02:32 PM
I'm not sure but that may be a contributing factor cuz the sender has sealer in it threaded into into a pipe extension with sealer threaded into an adapter with sealer on it which may be effecting the senders output signal
  #50 (permalink)
Old 07-18-2013, 03:37 PM
Project89's Avatar
this is why i always verify an electronic gauge against a mechanical
  #51 (permalink)
Old 07-18-2013, 04:49 PM
You're 100% right and so are rest of the guys who said it verifying with another electrical gauge is not good lol
  #52 (permalink)
Old 07-18-2013, 04:50 PM
Gonna try to do that today not sure if I'm man enough though since here in ny it's been crazy hot for the last two weeks at least and is especially uncomfortable today
  #53 (permalink)
Old 07-18-2013, 06:11 PM
Ok so checked with a mechanical gauge the pressure at idle is 50-51psi and at WOT is like 80-85
  #54 (permalink)
Old 07-19-2013, 08:33 AM
Does that sound about right to you guys?
  #55 (permalink)
Old 07-19-2013, 08:47 AM
Banned
sounds a little high, but not far off from normal. usually you're looking at about 40psi at idle, 65psi at WOT.
with your high pressure some people would move down a weight in oil viscosity- you'll see a little more flow that way and your pressure will drop a little. There are other factors to consider of course but it can be worth some power and mileage.
  #56 (permalink)
Old 07-19-2013, 09:53 AM
a lighter weight than 5w-30? thats really light already witht he turbo isnt it dangerous to run thinner oil than that?
  #57 (permalink)
Old 07-19-2013, 10:00 AM
Project89's Avatar
man u are brave, and i know alot of ppl will run that oil with a turbo, but i myself wont run anything other then 20-40 or rottella 15-40 in any of my turbo engines
but then again my engines are all set up loose on the bottom end and i modify the oil pumps as well
  #58 (permalink)
Old 07-19-2013, 10:57 AM
Banned
a good turbo can handle 0w-30 or 0w-20 with no problem provided you're not overheating anything and your tune is good.
An ebay turbo... I don't know. I'd probably run it at 0w-30 if I were you as it'll provide adequate pressure and more flow, and more flow is a good thing.
  #59 (permalink)
Old 07-19-2013, 11:49 AM
Yeah I may try it out next oil change and also I have to pull the restrictor and still it out
oil pressure sending unit leaks Lthompson Hotrodding Basics 11 10-03-2012 11:38 AM
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
Excessive oil pressure causing bearing erosion? jtybt15 Engine 8 04-14-2009 06:03 PM
Do I have a high volume or high pressure oil pump ? y2k600f4 Engine 6 12-16-2008 07:12 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
