Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Very Involved Problem 400sbc
  #21 (permalink)
Old 12-08-2012, 01:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cam has 226 int./234 exh. @ 0.050" lift and needs no where near 26 degrees initial. Start around 16-18 degrees initial and work up from there.
Generally it is better to get the timing worked out, then go on to carburetion- as long as it's running well enough to set the mechanical (should be all in by about 3K rpm).
